Displays known fabric attach assignment information.
| assignments | Display Fabric Attach assignments. |
| vlan | Designates specifying the VLAN. |
| vlan_name | Specifies VLAN name. |
| vlan_id | Specifies VLAN ID. |
N/A.
The following example shows Fabric Attach assignments information:
# show fabric attach assignments
Fabric Attach Mode: Proxy
Port VLAN VLAN Name Type ISID/NSI Status
100 VLAN_0100 Static 100 Active
400 v4 Static 400 Active
1000 VLAN_1000 Static 1000 Active
5 400 v4 Dynamic 404040 Rejected
9 20 SYS_VLAN_0020 Dynamic 20 Active
9 2500 SYS_VLAN_2500 Dynamic 25 Active
9 3500 SYS_VLAN_3500 Dynamic 35 Active
The following example shows Fabric Attach assignments information with ISID/NSI offset configured (line 3):
ISID/NSI Offset : 1000
1 Default Offset 1001 Active
100 v100 Static 100 Active
1001 SYS_VLAN_1001 Offset 2001 Active
2001 SYS_VLAN_2001 Dynamic 20001 Active
This command was first available in ExtremeXOS 30.2.
VLAN syntax was clarified in ExtremeXOS 30.5.
ISID/NSI offset information was added in version 33.1.1.
